Automating the configuration of StorageGRID
After deploying the grid nodes, you can automate the configuration of the StorageGRID system.
You know the location of the following files from the installation archive.
Filename Description configure-storagegrid.py
Python script used to automate the configuration
configure-storagegrid.sample.json
Sample configuration file for use with the script
configure-storagegrid.blank.json
Blank configuration file for use with the script
You have created a
configure-storagegrid.json
configuration file. To create this file, you can modify the sample configuration file (configure-storagegrid.sample.json
) or the blank configuration file (configure-storagegrid.blank.json
You can use the configure-storagegrid.py
Python script and the configure-storagegrid.json
configuration file to automate the configuration of your StorageGRID system.
You can also configure the system using the Grid Manager or the Installation API. |
Log in to the Linux machine you are using to run the Python script.
Change to the directory where you extracted the installation archive.
For example:
cd StorageGRID-Webscale-version/platform
where
platform
isdebs
,rpms
, orvsphere
Run the Python script and use the configuration file you created.
For example:
./configure-storagegrid.py ./configure-storagegrid.json --start-install
A Recovery Package .zip
file is generated during the configuration process, and it is downloaded to the directory where you are running the installation and configuration process. You must back up the Recovery Package file so that you can recover the StorageGRID system if one or more grid nodes fails. For example, copy it to a secure, backed up network location and to a secure cloud storage location.
The Recovery Package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system. |
If you specified that random passwords should be generated, you need to extract the Passwords.txt
file and look for the passwords required to access your StorageGRID system.
###################################################################### ##### The StorageGRID "recovery package" has been downloaded as: ##### ##### ./sgws-recovery-package-994078-rev1.zip ##### ##### Safeguard this file as it will be needed in case of a ##### ##### StorageGRID node recovery. ##### ######################################################################
Your StorageGRID system is installed and configured when a confirmation message is displayed.
StorageGRID has been configured and installed.
