      Editing a group name
You can edit the display name for a group. You cannot edit the unique name for a group.
What you'll need
You must be signed in to the Tenant Manager using a supported browser.
You must belong to a user group that has the Root Access permission.
Steps
Select ACCESS MANAGEMENT > Groups.
Select the check box for the group whose display name you want to edit.
Select Actions > Edit group name. The Edit group name dialog box appears.
If you are editing a local group, update the display name as needed. You cannot change a group's unique name. You cannot edit the display name for a federated group.
Select Save changes. A confirmation message appears in the upper right corner of the page. Changes might take up to 15 minutes to take effect because of caching.
Related information
 PDFs
PDFs
