      Disabling single sign-on
You can disable single sign-on (SSO) if you no longer want to use this functionality. You must disable single sign-on before you can disable identity federation.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Steps
Select Configuration > Access Control > Single Sign-on.
The Single Sign-on page appears.
Select the Disabled option.
Click Save.
A warning message appears indicating that local users will now be able to sign in.
Click OK.
The next time you sign in to StorageGRID, the StorageGRID Sign in page appears and you must enter the username and password for a local or federated StorageGRID user.
