Controlling which client operations are permitted
You can select the Prevent Client Modification grid option to deny specific HTTP client operations.
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Prevent Client Modification is a system wide setting. When the Prevent Client Modification option is selected, the following requests are denied:
S3 REST API -
Delete Bucket requests
Any requests to modify an existing object's data, user-defined metadata, or S3 object tagging This setting does not apply to buckets with versioning enabled. Versioning already prevents modifications to object data, user-defined metadata, and object tagging.
Swift REST API -
Delete Container requests
Requests to modify any existing object. For example, the following operations are denied: Put Overwrite, Delete, Metadata Update, and so on.
Select Configuration > System Settings > Grid Options.
In the Network Options section, select the Prevent Client Modification check box.
Click Save.
 PDFs
PDFs
