Setting the IP address for the BMC management port
Before you can access the BMC interface, you must configure the IP address for the BMC management port on the SG6000-CN controller.
The management client is using a supported web browser.
You are using any management client that can connect to a StorageGRID network.
The BMC management port is connected to the management network you plan to use.
For support purposes, the BMC management port allows low-level hardware access.
You should only connect this port to a secure, trusted, internal management network. If no such network is available, leave the BMC port unconnected or blocked, unless a BMC connection is requested by technical support. |
From the client, enter the URL for the StorageGRID Appliance Installer:
https://SG6000-CN_Controller_IP:8443For
SG6000-CN_Controller_IP, use the IP address for the appliance on any StorageGRID network.The StorageGRID Appliance Installer Home page appears.
Select Configure Hardware > BMC Configuration.
The Baseboard Management Controller Configuration page appears.
Make a note of the IPv4 address that is automatically displayed.
DHCP is the default method for assigning an IP address to this port.
It might take a few minutes for the DHCP values to appear.
Optionally, set a static IP address for the BMC management port.
You should either assign a static IP for the BMC management port or assign a permanent lease for the address on the DHCP server. -
Select Static.
Enter the IPv4 address, using CIDR notation.
Enter the default gateway.
Click Save.
It might take a few minutes for your changes to be applied.
