Updating subnets for the Grid Network
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
When you add grid nodes or a new site in an expansion, you might need to update or add subnets to the Grid Network.
StorageGRID maintains a list of the network subnets used to communicate between grid nodes on the Grid Network (eth0). These entries include the subnets used for the Grid Network by each site in your StorageGRID system as well as any subnets used for NTP, DNS, LDAP, or other external servers accessed through the Grid Network gateway.
You must be signed in to the Grid Manager using a supported browser.
You must have the Maintenance or Root Access permission.
You must have the provisioning passphrase.
You must have the network addresses, in CIDR notation, of the subnets you want to configure.
If you are performing an expansion activity that includes adding a new subnet, you must add the new Grid subnet before you start the expansion procedure.
Select Maintenance > Network > Grid Network.
In the Subnets list, click the plus sign to add a new subnet in CIDR notation.
For example, enter 10.96.104.0/22.
Enter the provisioning passphrase, and click Save.
The subnets you have specified are configured automatically for your StorageGRID system.
