Deleting a group
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can delete a group from the system. Any users who belong only to that group will no longer be able to sign in to the Tenant Manager or use the tenant account.
What you'll need
You must be signed in to the Tenant Manager using a supported browser.
You must belong to a user group that has the Root Access permission.
Steps
Select ACCESS MANAGEMENT > Groups.
Select the check boxes for the groups you want to delete.
Select Actions > Delete group.
A confirmation message appears.
Select Delete group to confirm you want to delete the groups indicated in the confirmation message.
A confirmation message appears in the upper right corner of the page. Changes might take up to 15 minutes to take effect because of caching.
Related information
