Automating grid node deployment in VMware vSphere
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can automate the deployment of StorageGRID grid nodes in VMware vSphere.
You have access to a Linux/Unix system with Bash 3.2 or later.
You have VMware OVF Tool 4.1 installed and correctly configured.
You know the username and password required to access VMware vSphere using the OVF Tool.
You know the virtual infrastructure (VI) URL for the location in vSphere where you want to deploy the StorageGRID virtual machines. This URL will typically be a vApp, or Resource Pool. For example:
vi://vcenter.example.com/vi/sgws
You can use the VMware ovftool
utility to determine this value (see theovftool
documentation for details).If you are deploying to a vApp, the virtual machines will not start automatically the first time, and you must power them on manually. -
You have collected all the required information for the configuration file. See Collecting information about your deployment environment for information.
You have access to the following files from the VMware installation archive for StorageGRID:
Filename | Description |
The virtual machine disk file that is used as a template for creating grid node virtual machines. Note: This file must be in the same folder as the |
The Open Virtualization Format template file ( |
The template file ( |
The Bash shell script used to automate the deployment of virtual grid nodes. |
The sample configuration file for use with the |
