Rebooting a grid node from the Grid Manager
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
Rebooting a grid node from the Grid Manager issues the reboot
command on the target node.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have the Maintenance or Root Access permission.
You must have the provisioning passphrase.
Steps
Select Nodes.
Select the grid node you want to reboot.
Select the Tasks tab.
Click Reboot.
A confirmation dialog box appears.
If you are rebooting the primary Admin Node, the confirmation dialog box reminds you that your browser's connection to the Grid Manager will be lost temporarily when services are stopped. -
Enter the provisioning passphrase, and click OK.
Wait for the node to reboot.
It might take some time for services to shut down.
When the node is rebooting, the gray icon (Administratively Down) appears on the left side of the Nodes page. When all services have started again, the icon changes back to its original color.
