Configuring storage pools
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
When defining an ILM rule, you use storage pools to specify where objects are stored . Before creating a storage pool, you must review the storage pool guidelines.
