Navigating to the Grid Manager
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You use the Grid Manager to define all of the information required to configure your StorageGRID system.
What you'll need
The primary Admin Node must be deployed and have completed the initial startup sequence.
Steps
Open your web browser and navigate to one of the following addresses:
https://primary_admin_node_ip client_network_ip
Alternatively, you can access the Grid Manager on port 8443:
https://primary_admin_node_ip:8443
You can use the IP address for the primary Admin Node IP on the Grid Network or on the Admin Network, as appropriate for your network configuration. |
Click Install a StorageGRID system.
The page used to configure a StorageGRID grid appears.
