Viewing current status of a service
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can view the current status of a services running on a grid node at any time.
What you'll need
You must have the Passwords.txt
file.
Steps
Log in to the grid node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
When you are logged in as root, the prompt changes from
to#
View the current status of a service running on a grid node: `service servicename status The current status of the requested service running on the grid node is reported (running or not). For example:
cmn running for 1d, 14h, 21m, 2s
Log out of the command shell:
exit
