Linux: Importing the node on the target host
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
After exporting the node from the source host, you import and validate the node on the target Linux host. Validation confirms that the node has access to the same block storage and network interface devices as it had on the source host.
Run the following command on the target Linux host.
Import the node on the target host.
sudo storagegrid node import /dev/mapper/sgws-dc1-s3-var-local
Finished importing node DC1-S3 from /dev/mapper/sgws-dc1-s3-var-local.
You should run 'storagegrid node validate DC1-S3'
Validate the node configuration on the new host.
sudo storagegrid node validate DC1-S3
Confirming existence of node DC1-S3... PASSED
Checking configuration file /etc/storagegrid/nodes/DC1-S3.conf for node DC1-S3... PASSED
Checking for duplication of unique values... PASSED
If any validation errors occur, address them before starting the migrated node.
For troubleshooting information, see the StorageGRID installation instructions for your Linux operating system.
