Planning a StorageGRID expansion
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can expand StorageGRID to increase storage capacity, to add metadata capacity, to add redundancy or new capabilities, or to add a new site. The number, type, and location of the nodes you need to add depends on the reason for the expansion.
