Types of text reports
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Text reports display a textual representation of attribute data values that have been processed by the NMS service. There are two types of reports generated depending on the time period you are reporting on: raw text reports for periods less than a week, and aggregate text reports for time periods greater than a week.
Raw text reports
A raw text report displays details about the selected attribute:
Time Received: Local date and time that a sample value of an attribute's data was processed by the NMS service.
Sample Time: Local date and time that an attribute value was sampled or changed at the source.
Value: Attribute value at sample time.
Aggregate text reports
An aggregate text report displays data over a longer period of time (usually a week) than a raw text report. Each entry is the result of summarizing multiple attribute values (an aggregate of attribute values) by the NMS service over time into a single entry with average, maximum, and minimum values that are derived from the aggregation.
Each entry displays the following information:
Aggregate Time: Last local date and time that the NMS service aggregated (collected) a set of changed attribute values.
Average Value: The average of the attribute's value over the aggregated time period.
Minimum Value: The minimum value over the aggregated time period.
Maximum Value: The maximum value over the aggregated time period.
