Obtaining additional equipment and tools (SG5700)
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
Before installing the StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
You need the following additional equipment to install and configure the hardware:
Screwdrivers
Phillips No. 2 screwdriver
Medium flat-blade screwdriver
ESD wrist strap
Optical cables and SFP transceivers
Optical cables for the 10/25-GbE ports you plan to use
Optional: SFP28 transceivers if you want to use 25-GbE link speed
Ethernet cables
Service laptop
Supported web browser
SSH client, such as PuTTY
1-Gb (RJ-45) Ethernet port
Optional tools
Power drill with Phillips head bit
Flashlight
Mechanized lift for SG5760
