System audit messages
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You should be familiar with audit messages belonging to the system audit category. These are events related to the auditing system itself, grid node states, system-wide task activity (grid tasks), and service backup operations, so that you can address potential issues.
Code | Message title and description | See |
ECOC |
Corrupt Erasure Coded Data Fragment: Indicates that a corrupt erasure coded data fragment has been detected. |
ETAF |
Security Authentication Failed: A connection attempt using Transport Layer Security (TLS) failed. |
GNRG |
GNDS Registration: A service updated or registered information about itself in the StorageGRID system. |
GNUR |
GNDS Unregistration: A service has unregistered itself from the StorageGRID system. |
GTED |
Grid Task Ended: The CMN service finished processing the grid task. |
GTST |
Grid Task Started: The CMN service started to process the grid task. |
GTSU |
Grid Task Submitted: A grid task was submitted to the CMN service. |
IDEL |
ILM Initiated Delete: This audit message is generated when ILM starts the process of deleting an object. |
LKCU |
Overwritten Object Cleanup. This audit message is generated when an overwritten object is automatically removed to free up storage space. |
LLST |
Location Lost: This audit message is generated when a location is lost. |
OLST |
Object Lost: A requested object cannot be located within the StorageGRID system. |
ORLM |
Object Rules Met: Object data is stored as specified by the ILM rules. |
SADD |
Security Audit Disable: Audit message logging was turned off. |
SADE |
Security Audit Enable: Audit message logging has been restored. |
SVRF |
Object Store Verify Fail: A content block failed verification checks. |
SVRU |
Object Store Verify Unknown: Unexpected object data detected in the object store. |
SYSD |
Node Stop: A shutdown was requested. |
SYST |
Node Stopping: A service initiated a graceful stop. |
SYSU |
Node Start: A service started; the nature of the previous shutdown is indicated in the message. |
VLST |
User Initiated Volume Lost: The |
