Preparing the site (SG5600)
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
Before installing the appliance, you must make sure that the site and the cabinet or rack you plan to use meet the specifications for a StorageGRID appliance.
Steps
Confirm that the site meets the requirements for temperature, humidity, altitude range, airflow, heat dissipation, wiring, power, and grounding. See the NetApp Hardware Universe for more information.
Obtain a 19-inch (48.3-cm) cabinet or rack to fit shelves of this size (without cables):
Appliance model Height Width Depth Maximum weight SG5612
(12 drives)
3.40 in.
(8.64 cm)
19.0 in.
(48.26 cm)
21.75 in.
(55.25 cm)
59.5 lb
(27 kg)
SG5660
(60 drives)
7.00 in.
(17.78 cm)
17.75 in.
(45.08 cm)
32.50 in.
(82.55 cm)
236.2 lb.
(107.1 kg)
Install any required network switches. See the NetApp Interoperability Matrix Tool for compatibility information.
Related information
