Editing a Cloud Storage Pool
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can edit a Cloud Storage Pool to change its name, service endpoint, or other details; however, you cannot change the S3 bucket or Azure container for a Cloud Storage Pool.
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
You must have reviewed the guidelines for configuring Cloud Storage Pools.
Select ILM > Storage Pools.
The Storage Pools page appears. The Cloud Storage Pools table lists the existing Cloud Storage Pools.
Select the radio button for the Cloud Storage Pool you want to edit.
Click Edit.
As required, change the display name, service endpoint, authentication credentials, or certificate validation method.
You cannot change the provider type or the S3 bucket or Azure container for a Cloud Storage Pool. If you previously uploaded a server or client certificate, you can select View Current to review the certificate that is currently in use.
Click Save.
When you save a Cloud Storage Pool, StorageGRID validates that the bucket or container and the service endpoint exist, and that they can be reached using the credentials that you specified.
If Cloud Storage Pool validation fails, an error message is displayed. For example, an error might be reported if there is a certificate error.
See the instructions for troubleshooting Cloud Storage Pools, resolve the issue, and then try saving the Cloud Storage Pool again.
