Testing the connection for a platform services endpoint
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If the connection to a platform service has changed, you can test the connection for the endpoint to validate that the destination resource exists and that it can be reached using the credentials you specified.
You must be signed in to the Tenant Manager using a supported browser.
You must belong to a user group that has the Manage Endpoints permission.
StorageGRID does not validate that the credentials have the correct permissions.
Select STORAGE (S3) > Platform services endpoints.
The Platform services endpoints page appears and shows the list of platform services endpoints that have already been configured.
Select the endpoint whose connection you want to test.
The endpoint details page appears.
Select Test connection.
A success message appears if the endpoint can be reached using the specified credentials. The connection to the endpoint is validated from one node at each site.
An error message appears if endpoint validation fails. If you need to modify the endpoint to correct the error, select Configuration and update the information. Then, select Test and save changes.
