Hardware setup appears to hang
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
The StorageGRID Appliance Installer might not be available if hardware faults or cabling errors prevent the storage controllers or the SG6000-CN controller from completing their boot-up processing.
Steps
For the storage controllers, watch the codes on the seven-segment displays.
While the hardware is initializing during power up, the two seven-segment displays show a sequence of codes. When the hardware boots successfully, both seven-segment displays show
99
Review the LEDs on the SG6000-CN controller and the boot-up and error codes displayed in the BMC.
If you need help resolving an issue, contact technical support.
Related information
Viewing boot-up status codes for the SG6000 storage controllers
