Obtaining the required materials for a software upgrade
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Before you begin the software upgrade, you must obtain all required materials so you can complete the upgrade successfully.
Item | Notes |
StorageGRID upgrade files |
You must download the required files to your service laptop:
Service laptop |
The service laptop must have:
Supported web browser |
You must confirm that the web browser on the service laptop is supported for use with StorageGRID 11.5. Note: Browser support has changed for StorageGRID 11.5. Confirm you are using a supported version. |
Recovery Package ( |
Before upgrading, you should download the most recent Recovery Package file in case any problems occur during the upgrade. After you upgrade the primary Admin Node, you must download a new copy of the Recovery Package file and save it in a safe location. The updated Recovery Package file allows you to restore the system if a failure occurs. |
This file is included in the SAID package, which is part of the Recovery Package |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the |
Related documentation |
