Adding users to a local group
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can add users to a local group as needed.
What you'll need
You must be signed in to the Tenant Manager using a supported browser.
You must belong to a user group that has the Root Access permission.
Steps
Select ACCESS MANAGEMENT > Groups.
Select the name of the local group you want to add users to.
Alternatively, you can select Actions > View group details.
The group details page appears.
Select Manage Users, and then select Add users.
Select the users you want to add to the group, and then select Add users.
A confirmation message appears in the upper right corner of the page. Changes might take up to 15 minutes to take effect because of caching.
