Recovering from non-primary Admin Node failures
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You must complete the following tasks to recover from a non-primary Admin Node failure. One Admin Node hosts the Configuration Management Node (CMN) service and is known as the primary Admin Node. Although you can have multiple Admin Nodes, each StorageGRID system includes only one primary Admin Node. All other Admin Nodes are non-primary Admin Nodes.
Related information
Steps
Selecting Start Recovery to configure a non-primary Admin Node
Restoring the audit log on the recovered non-primary Admin Node
Resetting the preferred sender on the recovered non-primary Admin Node
Restoring the Admin Node database when recovering a non-primary Admin Node
Restoring Prometheus metrics when recovering a non-primary Admin Node
