Configuring audit clients for Workgroup
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Perform this procedure for each Admin Node in a StorageGRID deployment from which you want to retrieve audit messages.
You must have the
Passwords.txt
file with the root/admin account password (available in the SAID package). -
You must have the
Configuration.txt
file (available in the SAID package).
Audit export through CIFS/Samba has been deprecated and will be removed in a future StorageGRID release.
Log in to the primary Admin Node:
Enter the following command:
ssh admin@primary_Admin_Node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.When you are logged in as root, the prompt changes from
to#
Confirm that all services have a state of Running or Verified:
storagegrid-status
If all services are not Running or Verified, resolve issues before continuing.
Return to the command line, press Ctrl+C.
Start the CIFS configuration utility:
config_cifs.rb
--------------------------------------------------------------------- | Shares | Authentication | Config | --------------------------------------------------------------------- | add-audit-share | set-authentication | validate-config | | enable-disable-share | set-netbios-name | help | | add-user-to-share | join-domain | exit | | remove-user-from-share | add-password-server | | | modify-group | remove-password-server | | | | add-wins-server | | | | remove-wins-server | | ---------------------------------------------------------------------
Set the authentication for the Windows Workgroup:
If authentication has already been set, an advisory message appears. If authentication has already been set, go to the next step.
Enter:
set-authentication
When prompted for Windows Workgroup or Active Directory installation, enter:
workgroup
When prompted, enter a name of the Workgroup:
workgroup_name
When prompted, create a meaningful NetBIOS name:
netbios_name
or
Press Enter to use the Admin Node's hostname as the NetBIOS name.
The script restarts the Samba server and changes are applied. This should take less than one minute. After setting authentication, add an audit client.
When prompted, press Enter.
The CIFS configuration utility is displayed.
Add an audit client:
Enter:
add-audit-share
The share is automatically added as read-only. -
When prompted, add a user or group:
user
When prompted, enter the audit user name:
audit_user_name
When prompted, enter a password for the audit user:
password
When prompted, re-enter the same password to confirm it:
password
There is no need to enter a directory. The audit directory name is predefined. -
If more than one user or group is permitted to access the audit share, add the additional users:
Enter:
add-user-to-share
A numbered list of enabled shares is displayed.
When prompted, enter the number of the audit-export share:
share_number
user
or
group
When prompted, enter the name of the audit user or group:
audit_user or audit_group
Repeat these substeps for each additional user or group that has access to the audit share.
Optionally, verify your configuration:
validate-config
The services are checked and displayed. You can safely ignore the following messages:
Can't find include file /etc/samba/includes/cifs-interfaces.inc Can't find include file /etc/samba/includes/cifs-filesystem.inc Can't find include file /etc/samba/includes/cifs-custom-config.inc Can't find include file /etc/samba/includes/cifs-shares.inc rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
The audit client configuration is displayed.
Close the CIFS configuration utility:
exit
Start the Samba service:
service smbd start
If the StorageGRID deployment is a single site, go to the next step.
or
Optionally, if the StorageGRID deployment includes Admin Nodes at other sites, enable these audit share as required:
Remotely log in to a site's Admin Node:
ssh admin@grid_node_IP
Passwords.txt
file. -
su -
Passwords.txt
file.
Repeat the steps to configure the audit share for each additional Admin Node.
Close the remote secure shell login to the remote Admin Node:
exit
Log out of the command shell:
exit
