Starting or restarting a service
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You might need to start a service that has been stopped, or you might need to stop and restart a service.
You must have the Passwords.txt
file.
Log in to the grid node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
When you are logged in as root, the prompt changes from
to#
Decide which command to issue, based on whether the service is currently running or stopped.
If the service is currently stopped, use the
start
command to start the service manually:service servicename start
For example:
service ldr start
If the service is currently running, use the
restart
command to stop the service and then restart it:service servicename restart
For example:
service ldr restart
Using the restart
command is the same as using thestop
command followed by thestart
command. You can issuerestart
even if the service is currently stopped.
Log out of the command shell:
exit
