StorageGRID appliance features
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
The StorageGRID SG5600 appliance provides an integrated storage solution for creating a new StorageGRID system or for expanding the capacity of an existing system.
The StorageGRID appliance provides the following features:
Combines the StorageGRID Storage Node computing and storage elements into a single, efficient, integrated solution
Simplifies the installation and configuration of a Storage Node, automating most of the process required
Provides a high-density storage solution with two enclosure options: one that is 2U and one that is 4U
Uses 10-GbE IP interfaces directly to the Storage Node, without the need for intermediate storage interfaces such as FC or iSCSI
Can be used in a hybrid grid environment that uses StorageGRID appliances and virtual (software-based) Storage Nodes
Includes preconfigured storage and comes preloaded with the StorageGRID Appliance Installer (on the E5600SG controller) for field-ready software deployment and integration
