Starting the StorageGRID host service
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
To start your StorageGRID nodes, and ensure they restart after a host reboot, you must enable and start the StorageGRID host service.
Run the following commands on each host:
sudo systemctl enable storagegrid sudo systemctl start storagegrid
Run the following command to ensure the deployment is proceeding:
sudo storagegrid node status node-name
For any node that returns a status of Not-Running or Stopped, run the following command:
sudo storagegrid node start node-name
If you have previously enabled and started the StorageGRID host service (or if you are unsure if the service has been enabled and started), also run the following command:
sudo systemctl reload-or-restart storagegrid
