Setting passwords for SANtricity Storage Manager
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can set the passwords used for the appliance in SANtricity Storage Manager. Setting passwords maintains system security.
Steps
From the Enterprise Management Window in SANtricity Storage Manager, double-click the controller.
From the Array Management Window, select the Storage Array menu, and select Security > Set Password.
Configure the passwords.
Use SANtricity Storage Manager online help, if needed, to complete the task.
