Disabling identity federation
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you configured an identity federation service for this tenant, you can temporarily or permanently disable identity federation for tenant groups and users. When identity federation is disabled, there is no communication between the StorageGRID system and the identity source. However, any settings you have configured are retained, allowing you to easily re-enable identity federation in the future.
You must be signed in to the Tenant Manager using a supported browser.
You must have specific access permissions.
Before you disable identity federation, you should be aware of the following:
Federated users will be unable to sign in.
Federated users who are currently signed in will retain access to the tenant account until their session expires, but they will be unable to sign in after their session expires.
Synchronization between the StorageGRID system and the identity source will not occur.
Select ACCESS MANAGEMENT > Identity federation.
Deselect the Enable identity federation check box.
Select Save.
