Gathering required materials
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Before performing a grid node decommission, you must obtain the following information.
Item | Notes |
Recovery Package |
You must download the most recent Recovery Package |
This file contains the passwords required to access grid nodes on the command line and is included in the Recovery Package. |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not in the |
Description of StorageGRID system's topology before decommissioning |
If available, obtain any documentation that describes the system's current topology. |
