Execution Hook overview
Beitragende
Sammlung separater PDF-Dokumente
Creating your file...
Your file is ready
The Execution Hook API provides CRUD (Create-Read-Update-Delete) access to executionHook resources in order to allow simple management of execution hooks. Execution hooks contain additional configuration and references to a hook source resource.
