Análisis específico basado en fecha y copia de datos
Colaboradores
PDF de este sitio de documentos
Inteligencia artificial
Cloud público e híbrido
Virtualización
Virtualización con VMware
Contenedores
Red Hat OpenShift con NetApp
Recopilación de documentos PDF independientes
Creating your file...
Your file is ready
Esta solución se basa en un cliente que necesita copiar datos basándose en una fecha específica. Compruebe los siguientes detalles:
Created a file in Y: and checked the scan command to list them. c:\XCP>dir Y:\karthik_test Volume in drive Y is from Volume Serial Number is 80F1-E201 Directory of Y:\karthik_test 05/26/2020 02:51 PM <DIR> . 05/26/2020 02:50 PM <DIR> .. 05/26/2020 02:51 PM 2,295 testfile.txt 1 File(s) 2,295 bytes 2 Dir(s) 658,747,392 bytes free c:\XCP> c:\XCP>xcp scan -match "strftime(ctime,'%Y-%m-%d')>'2020-05-01'" -fmt "'{},{}'.format(iso(mtime),name)" Y:\ XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to Calin Salagean [NetApp Inc] until Mon Dec 31 00:00:00 2029 It appears that you are not running XCP as Administrator. To avoid access issues please run XCP as Administrator. 2020-05-26_14:51:13.132465,testfile.txt 2020-05-26_14:51:00.074216,karthik_test xcp scan -match strftime(ctime,'%Y-%m-%d')>'2020-05-01' -fmt '{},{}'.format(iso(mtime),name) Y:\ : PASSED 30,205 scanned, 2 matched, 0 errors Total Time : 4s STATUS : PASSED Copy the files based on date (2020 YearMay month first date) from Y: to Z: c:\XCP>xcp copy -match "strftime(ctime,'%Y-%m-%d')>'2020-05-01'" Y: Z:\dest_karthik XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to Calin Salagean [NetApp Inc] until Mon Dec 31 00:00:00 2029 It appears that you are not running XCP as Administrator. To avoid access issues please run XCP as Administrator. 30,205 scanned, 3 matched, 0 copied, 0 errors, 5s xcp copy -match strftime(ctime,'%Y-%m-%d')>'2020-05-01' Y: Z:\dest_karthik : PASSED 30,205 scanned, 3 matched, 2 copied, 0 errors Total Time : 6s STATUS : PASSED c:\XCP> Check the destination Z: c:\XCP>dir Z:\dest_karthik\karthik_test Volume in drive Z is to Volume Serial Number is 80F1-E202 Directory of Z:\dest_karthik\karthik_test 05/26/2020 02:51 PM <DIR> . 05/26/2020 02:50 PM <DIR> .. 05/26/2020 02:51 PM 2,295 testfile.txt 1 File(s) 2,295 bytes 2 Dir(s) 659,316,736 bytes free c:\XCP>
