Script para agregar una licencia de nodo ONTAP Select
Puede utilizar el siguiente script para agregar una licencia para un nodo ONTAP Select .
#!/usr/bin/env python
# File: add_license.py
# (C) Copyright 2019 NetApp, Inc.
# This sample code is provided AS IS, with no support or warranties of
# any kind, including but not limited for warranties of merchantability
# or fitness of any kind, expressed or implied. Permission to use,
# reproduce, modify and create derivatives of the sample code is granted
# solely for the purpose of researching, designing, developing and
# testing a software application product for use with NetApp products,
# provided that the above copyright notice appears in all copies and
# that the software application product is distributed pursuant to terms
# no less restrictive than those set forth herein.
import argparse
import logging
import json
from deploy_requests import DeployRequests
def post_new_license(deploy, license_filename):
log_info('Posting a new license: {}'.format(license_filename))
# Stream the file as multipart/form-data
deploy.post('/licensing/licenses', data={},
files={'license_file': open(license_filename, 'rb')})
# Alternative if the NLF license data is converted to a string.
# with open(license_filename, 'rb') as f:
# nlf_data = f.read()
# r = deploy.post('/licensing/licenses', data={},
# files={'license_file': (license_filename, nlf_data)})
def put_license(deploy, serial_number, data, files):
log_info('Adding license for serial number: {}'.format(serial_number))
deploy.put('/licensing/licenses/{}'.format(serial_number), data=data, files=files)
def put_used_license(deploy, serial_number, license_filename, ontap_username, ontap_password):
''' If the license is used by an 'online' cluster, a username/password must be given. '''
data = {'ontap_username': ontap_username, 'ontap_password': ontap_password}
files = {'license_file': open(license_filename, 'rb')}
def put_free_license(deploy, serial_number, license_filename):
data = {}
def get_serial_number_from_license(license_filename):
''' Read the NLF file to extract the serial number '''
with open(license_filename) as f:
data = json.load(f)
statusResp = data.get('statusResp', {})
serialNumber = statusResp.get('serialNumber')
if not serialNumber:
log_and_exit("The license file seems to be missing the serialNumber")
return serialNumber
def log_info(msg):
logging.getLogger('deploy').info(msg)
def log_and_exit(msg):
logging.getLogger('deploy').error(msg)
exit(1)
def configure_logging():
FORMAT = '%(asctime)-15s:%(levelname)s:%(name)s: %(message)s'
logging.basicConfig(level=logging.INFO, format=FORMAT)
logging.getLogger('requests.packages.urllib3.connectionpool').setLevel(logging.WARNING)
def main(args):
configure_logging()
serial_number = get_serial_number_from_license(args.license)
deploy = DeployRequests(args.deploy, args.password)
# First check if there is already a license resource for this serial-number
if deploy.find_resource('/licensing/licenses', 'id', serial_number):
# If the license already exists in the Deploy server, determine if its used
if deploy.find_resource('/clusters', 'nodes.serial_number', serial_number):
# In this case, requires ONTAP creds to push the license to the node
if args.ontap_username and args.ontap_password:
put_used_license(deploy, serial_number, args.license,
args.ontap_username, args.ontap_password)
else:
print("ERROR: The serial number for this license is in use. Please provide ONTAP credentials.")
else:
# License exists, but its not used
put_free_license(deploy, serial_number, args.license)
else:
# No license exists, so register a new one as an available license for later use
post_new_license(deploy, args.license)
def parseArgs():
parser = argparse.ArgumentParser(description='Uses the ONTAP Select Deploy API to add or update a new or used NLF license file.')
parser.add_argument('-d', '--deploy', required=True, type=str, help='Hostname or IP address of ONTAP Select Deploy')
parser.add_argument('-p', '--password', required=True, type=str, help='Admin password of Deploy server')
parser.add_argument('-l', '--license', required=True, type=str, help='Filename of the NLF license data')
parser.add_argument('-u', '--ontap_username', type=str,
help='ONTAP Select username with privelege to add the license. Only provide if the license is used by a Node.')
parser.add_argument('-o', '--ontap_password', type=str,
help='ONTAP Select password for the ontap_username. Required only if ontap_username is given.')
return parser.parse_args()
if __name__ == '__main__':
args = parseArgs()
main(args)
