SnapCenter Plug-in for VMware vSphere 5.0
Privilegios mínimos requeridos de vCenter
Colaboradores
Antes de iniciar la implementación del plugin de SnapCenter para VMware vSphere, debe asegurarse de contar con los privilegios mínimos de vCenter requeridos.
Privilegios requeridos para la función de administrador de vCenter
Datastore.AllocateSpace Datastore.Browse Datastore.Delete Datastore.FileManagement Datastore.Move Datastore.Rename Extension.Register Extension.Unregister Extension.Update Host.Config.AdvancedConfig Host.Config.Resources Host.Config.Host.Config.Config.Storage Host.Local.CreateVM Host.Local.DeleteVM Host.Local.ReconfigVM Network.Assign Resource.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.VirtualMachine.Virtual
Privilegios requeridos específicos del plugin de SnapCenter para VMware vCenter
Privilegios
Etiqueta
NetappSCV.Guest.RestoreFile
Restauración de archivos invitados
NetappSCV.Recovery.MountUnMount
Montar/desmontar
NetappSCV.Backup.DeleteBackupJob
Eliminar grupo de recursos/copia de seguridad
NetappSCV.Configure.ConfigureStorageSystems.Delete
Quitar sistemas de almacenamiento
NetappSCV.View
Ver
NetappSCV.Recovery.RecoverVM
Recuperar la máquina virtual
NetappSCV.Configure.ConfigureStorageSystems.AddUpdate
Añadir/modificar sistemas de almacenamiento
NetappSCV.Backup.BackupNow
Realice su backup ahora
NetappSCV.Guest.Configure
Configuración de invitado
NetappSCV.Configure.ConfigureSnapCenter Server
Configure el servidor SnapCenter
NetappSCV.Backup.BackupExeted
Crear grupo de recursos
