Retrieve a feature
Contributeurs
GET /accounts/{account_id}/core/v1/features/{feature_id}
Returns the stored Feature API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
feature_id
string
path
True
ID of the feature collection to list
Status: 200, Returns the stored Feature API resource in the JSON response body.
type
string
True
  • "application/astra-feature"
version
string
True
  • "1.0"
id
string
True
name
string
True
JSON string containing a name for the feature, in hierarchal dot notation. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks.
isEnabled
string
True
JSON string containing a value indicating whether the feature flag is turned on or off. Defined values are:
  • "true" - The feature flag is enabled.
  • "false" - The feature flag is disabled.
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-feature",
  "version": "1.0",
  "id": "c4fdb3b8-9ca8-523d-b9d9-f7727b753612",
  "name": "astra.account.rbac",
  "isEnabled": "true",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
