List the role bindings for a user
Contributeurs
GET /accounts/{account_id}/core/v1/users/{user_id}/roleBindings
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
user_id
string
path
True
ID of the containing user resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: accountID,userID,role
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
skip
string
query
False
Indicates the number of resources to skip over when listing a collection.
URL examples: "skip=1"
OpenAPI examples: "1"
count
string
query
False
Indicates if the total number of resources should be returned in the metadata object.
URL examples: "count=true"
OpenAPI examples: "true"
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: roleBinding_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-roleBindings",
  "version": "1.1",
  "items": [
      "9fd87309-067f-48c9-a331-527796c14cf3",
      "4c27d25a-9edb-4e85-9438-48dc8e917231",
      "viewer"
      "dc40a13f-e9b3-4cf5-900f-58de32174390",
      "owner"
      "c38abd8d-7dae-4659-8382-2e74a58738ba",
      "owner"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-roleBinding"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
principalType
string
True
JSON string representing the type of the principal this binding is associated with. Defined values are:
  • "user"
  • "group" For principalType "user", a non-nil user ID is required. For principalType "group", a non-nil group ID is required.
userID
string
True
JSON string containing a user resource ID. Defined values are:
  • Conforms to the Astra Identifier Schema If not specified on create, a nil UUID will be used. Only userID or groupID can be specified on create.
groupID
string
True
JSON string containing a group resource ID. Defined values are:
accountID
string
True
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role
string
True
JSON string containing one of the four defined roles. Defined values are:
  • "viewer"
  • "member"
  • "admin"
  • "owner"
roleConstraints
array[string]
False
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
  • Conforms to Astra Role Constraints Schema If not specified on create, the value will be set to an array of size 1 containing string "*" representing "full scope". If not specified on update, the value will be preserved without modification. An empty array represents "no scope". Examples:
  • = Allow access to any resource: "roleConstraints": ["*"]
  • = deny access to all resources: "roleConstraints": []
  • = Allow access to a specific namespace resource only: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'" ]
  • = Allow access to a specific namespace and everything under it: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'.*" ]
  • = Allow access to all namespaces labelled "dev" in any cluster in any cloud, and everything under them: "roleConstraints": [ "namespaces:kubernetesLabels='dev.example.com/appname=dev'.*" ]
  • = Allow access to all namespace resources only: "roleConstraints": [ "namespaces:*" ]
  • = Allow access to all namespace resources and everything under them: "roleConstraints": [ "namespaces:." ]
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
