Hook source overview
Contributeurs
Suggérer des modifications
Plusieurs fichiers PDF
Creating your file...
Your file is ready
The Hook Source API provides CRUD (Create-Read-Update-Delete) access to hookSource resources in order to allow simple management of hook sources separate from the management of execution hook resources. For example, a single hook source can be referenced by multiple execution hooks which avoid duplicate hook sources and make it a single API call to update one hook source, even if it is used by multiple execution hook resources.
