Upgrade overview
Contributeurs
Plusieurs fichiers PDF
Creating your file...
Your file is ready
The Upgrade App API provides CRUD (Create-Read-Update-Delete) access to software components that are eligible for upgrade, and to initiate upgrades. The availability of upgrades is determined based on packages registered with the Packages API.
