Create a new schedule for an app
Contributeurs
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/schedules
Indicates desired values for the Schedule API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
Request Body
type
string
True
  • "application/astra-schedule"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
name
string
True
JSON string containing a name of the schedule. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
enabled
string
False
JSON string indicating if a schedule is active. Defined values are:
  • "true" - The schedule is active
  • "false" - The schedule is not active If not specified, the default value is "true".
granularity
string
True
JSON string indicating the granularity of the schedule. Defined values are:
  • "hourly"
  • "daily"
  • "weekly"
  • "monthly"
  • "custom"
minute
string
False
JSON string containing a numeric value indicating the minute of the hour (0 - 59) to execute the schedule. Defined values are:
  • Defined regex is: "^[0-9]|[1-5][0-9]$" This field is present if granularity is set to "hourly", "daily", "weekly", or "monthly". It will be returned with value "0" for custom schedules.
hour
string
False
JSON string containing a numeric value indicating the hour of the day (0 - 23) to execute the schedule. Defined values are:
  • Defined regex is: "^[0-9]|[1][0-9]|[2][0-3]$" This field is present if granularity is set to "daily", "weekly", or "monthly".
dayOfWeek
string
False
JSON string containing a numeric value indicating the day of the week (0-7) to execute the schedule. Defined values are:
  • Defined regex is: "^[0-7]$" This field is only present if granularity is set to "weekly".
dayOfMonth
string
False
JSON string containing a numeric value indicating the day of the month (1-31) to execute the schedule. Defined values are:
  • Defined regex is: "^[1-9]|[1-2][0-9]|[3][0-1]$" This field is only present if granularity is set to "monthly".
recurrenceRule
string
False
JSON string containing an RFC-5545 Section 3.8.5.3. Recurrence Rule. For the DTSTART parameter, only UTC timestamps (denoted by the "Z" suffix) are supported, and only timestamps before the current time are supported. For the RECUR rule parts, "FREQ" and "INTERVAL" are the only rule parts supported. For the FREQ rule part, "MINUTELY" and "HOURLY" are the only values supported. This field is only present if granularity is set to "custom".
snapshotRetention
string
True
JSON string containing a positive numeric value indicating how many snapshots to retain. Zero indicates that snapshots should be deleted after taking a backup. Defined values are:
  • Minimum length: 1
  • Defined regex is: "^(0|([1-9][0-9]*))$"
backupRetention
string
True
JSON string containing a positive numeric value indicating how many backups to retain. Zero indicates that no backups should be created. Defined values are:
  • Minimum length: 1
bucketID
string
False
JSON string containing an optional bucket ID indicating where the backup must be stored on create. If not specified, a system-selected bucket will be used. Defined values are:
  • Conforms to the Astra Identifier Schema
replicate
string
False
JSON string indicating if the schedule triggers AppMirror replication for each snapshot. Only takes effect if the application has an AppMirror relationship defined. Defined values are:
  • "true" - The schedule triggers AppMirror replication
  • "false" - The schedule does not trigger AppMirror replication If not specified, the default value is "false".
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-schedule",
  "version": "1.3",
  "name": "Backup Schedule",
  "enabled": "true",
  "granularity": "monthly",
  "minute": "0",
  "hour": "0",
  "dayOfMonth": "1",
  "snapshotRetention": "12",
  "backupRetention": "12"
Status: 201, Returns the newly created schedule resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
id
string
True
name
string
True
  • Minimum length: 1
enabled
string
True
granularity
string
True
  • "hourly"
  • "daily"
  • "weekly"
  • "monthly"
  • "custom"
minute
string
True
hour
string
False
dayOfWeek
string
False
dayOfMonth
string
False
recurrenceRule
string
False
snapshotRetention
string
True
  • Minimum length: 1
backupRetention
string
True
  • Minimum length: 1
bucketID
string
False
replicate
string
False
metadata
True
  "version": "1.3",
  "id": "49cbc480-5f7d-51e2-8f30-52b9a83a03b1",
  "enabled": "true",
  "minute": "0",
  "hour": "0",
  "dayOfMonth": "1",
  "backupRetention": "12",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
