Astra Automation
List the cluster nodes for a cloud
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters/{cluster_id}/clusterNodes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the containing cloud resource
cluster_id
string
path
True
ID of the containing cluster resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: name,instanceType
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: clusterNode_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-clusterNodes",
  "version": "1.0",
  "items": [
      "test-0",
      "e2-medium"
      "test-1",
      "e2-medium"
      "test-2",
      "e2-medium"
      "test-3",
      "e2-micro"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
labels
name
string
True
JSON string containing the label name Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Defined regex is: "^([\S.]{1,253}\/)?([a-z0-9A-Z_.-]){1,63}$"
value
string
True
JSON string containing the label value Defined values are:
  • Minimum length: 1
  • Defined regex is: "^([a-z0-9A-Z_.-]){1,63}$"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-clusterNode"
version
string
True
  • "1.0"
id
string
True
name
string
True
JSON string containing a value that indicates the Kubernetes name for the node. Defined values are:
  • Minimum length: 1
  • Maximum length: 254
role
string
True
JSON string containing a value that indicates the Kubernetes role for the node. Defined values are:
  • Minimum length: 1
labels
array[labels]
True
JSON array of JSON objects, each containing Kubernetes labels associated with the node. If no details are available, this array will be empty.
  • Minimum items: 0
creationTime
string
True
JSON string containing an ISO 8601 timestamp that indicates when the node was created. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
externalIP
string
True
JSON string containing a value that indicates the internal IP address for the node. Defined values are:
  • Minimum length: 1
internalIP
string
True
JSON string containing a value that indicates the external IP address for the node. Defined values are:
  • Minimum length: 1
zone
string
True
JSON string containing a value that indicates the Kubernetes zone for the node. Defined values are:
  • Minimum length: 1
region
string
True
JSON string containing a value that indicates the Kubernetes region for the node. Defined values are:
  • Minimum length: 1
instanceType
string
True
JSON string containing a value that indicates the Kubernetes instance type for the node. Defined values are:
  • Minimum length: 1
kernelVersion
string
True
JSON string containing a value that indicates the kernel version used by the node. Defined values are:
  • Minimum length: 1
osImage
string
True
JSON string containing a value that indicates the operating system image used by the node. Defined values are:
  • Minimum length: 1
numCpus
string
True
JSON string containing a value that indicates the number of CPUs assigned to the node. Defined values are:
  • Minimum length: 1
memory
string
True
JSON string containing a value that indicates the amount of memory assigned to the node. Defined values are:
  • Minimum length: 1
state
string
True
JSON string containing a value indicating the operational state of the node. Defined values are:
  • "running" - The node is running normally
  • "provisioning" - The node is in the process of being provisioned
  • "discovering" - Aspects of the node are in the process of being discovered
  • "pending" - The node is scheduled for discovery
  • "failed" - The node is in a failure state
  • "unknown" - The state of the node cannot be determined
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
