ONTAP Select
JSON pour le script permettant de créer un cluster ONTAP Select
Contributeurs netapp-revathid
Lors de la création ou de la suppression d'un cluster ONTAP Select à l'aide des exemples de code Python, vous devez fournir un fichier JSON en entrée du script. Vous pouvez copier et modifier l'exemple JSON approprié en fonction de vos plans de déploiement.
Cluster à nœud unique sur ESXi
  "hosts": [
      "password": "mypassword1",
      "name": "host-1234",
      "type": "ESX",
      "username": "admin"
  "cluster": {
    "dns_info": {
      "domains": ["lab1.company-demo.com", "lab2.company-demo.com",
        "lab3.company-demo.com", "lab4.company-demo.com"
      "dns_ips": ["10.206.80.135", "10.206.80.136"]
      "ontap_image_version": "9.7",
      "gateway": "10.206.80.1",
      "ip": "10.206.80.115",
      "name": "mycluster",
      "ntp_servers": ["10.206.80.183", "10.206.80.142"],
      "ontap_admin_password": "mypassword2",
      "netmask": "255.255.254.0"
  "nodes": [
      "serial_number": "3200000nn",
      "ip": "10.206.80.114",
      "name": "node-1",
      "networks": [
          "name": "ontap-external",
          "purpose": "mgmt",
          "vlan": 1234
          "purpose": "data",
          "vlan": null
          "name": "ontap-internal",
          "purpose": "internal",
          "vlan": null
      "host_name": "host-1234",
      "is_storage_efficiency_enabled": false,
      "instance_type": "small",
      "storage": {
        "disk": [],
        "pools": [
            "name": "storage-pool-1",
            "capacity": 4802666790125
Cluster à nœud unique sur ESXi utilisant vCenter
  "hosts": [
      "name":"host-1234",
      "type":"ESX",
      "mgmt_server":"vcenter-1234"
  "cluster": {
    "dns_info": {"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
      "dns_ips": ["10.206.80.135","10.206.80.136"]
  "ontap_image_version":"9.7",
  "gateway":"10.206.80.1",
  "ip":"10.206.80.115",
  "name":"mycluster",
  "ntp_servers": ["10.206.80.183","10.206.80.142"],
  "ontap_admin_password":"mypassword2",
  "netmask":"255.255.254.0"
  "vcenter": {
    "password":"mypassword2",
    "hostname":"vcenter-1234",
    "username":"selectadmin"
  "nodes": [
      "ip":"10.206.80.114",
      "name":"node-1",
      "networks": [
          "name":"ONTAP-Management",
          "purpose":"mgmt",
          "vlan":null
          "name": "ONTAP-External",
          "purpose":"data",
          "vlan":null
          "name": "ONTAP-Internal",
          "purpose":"internal",
          "vlan":null
      "storage": {
        "disk":[],
        "pools": [
            "capacity":5685190380748
Cluster à nœud unique sur KVM
  "hosts": [
      "name":"host-1234",
      "type":"KVM",
      "username":"root"
  "cluster": {
    "dns_info": {
    "name":"CBF4ED97",
  "nodes": [
      "serial_number":"3200000nn",
      "name": "node-1",
      "networks": [
          "purpose": "mgmt",
          "vlan":1234
          "purpose": "data",
          "vlan": null
          "vlan": null
      "storage": {
        "disk": [],
        "pools": [
