List all licenses
Collaboratori
GET /accounts/{account_id}/core/v1/licenses
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,product
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: license_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-licenses",
  "version": "1.0",
  "items": [
      "c8aa757a-5318-489f-8134-a2a1a6956a3e",
      "Astra SDS"
      "0f7cc03d-9afc-4192-af7f-b29ab24f8f2a",
      "Astra Enterprise"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
addons
startDate
string
False
JSON string containing a timestamp indicating when this add-on becomes valid. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
endDate
string
False
JSON string containing a timestamp indicating when this add-on is no longer valid. Defined values are:
features
string
False
JSON string containing the list of features associated with this add-on. Defined values are:
  • String contents not validated by the schema.
capacity
string
False
JSON string containing the capacity extracted from the add-on. Defined values are:
licenseProtocol
string
False
JSON string containing the license protocol associated with this add-on. Defined values are:
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-license"
version
string
True
  • "1.0"
id
string
True
allocation
string
False
JSON string containing an ID indicating what the license is allocated to. Only present when the license is allocated. For Astra Control Center licenses, this field must be populated with the account ID and must match the account ID specified in the POST URI. Defined values are:
  • Conforms to the Astra Identifier Schema
hostID
string
False
JSON string containing a host identifier that a license is bound to. Only present if the license is host-locked. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
deviceCredentialID
string
False
JSON string containing the identifier of the deviceCredential associated with the Credential API. Only present for Astra Data Store licenses. Defined value are:
isEvaluation
string
True
JSON string indicating whether the license is an evaluation license. Defined values are:
  • "true"
  • "false"
licenseProtocol
string
True
JSON string containing the license protocol extracted from the license. Defined values are:
licenseText
string
True
JSON string containing a base64 encoded representation of the license JSON as obtained from the NetApp license system. This must be provided in the original byte-level order to allow signature verification. Defined values are:
  • Conforms to the base64 Encoded Data Schema
validFromTimestamp
string
True
JSON string containing a timestamp indicating when the license becomes valid. Defined values are:
validUntilTimestamp
string
True
JSON string containing a timestamp indicating when the license is no longer valid. Defined values are:
product
string
True
JSON string containing the product string extracted from the license. Defined values are:
productVersion
string
True
JSON string containing the version string extracted from the license. Defined values are:
productSN
string
True
JSON string containing the serial number string extracted from the license. Defined values are:
features
string
True
JSON string containing the package value extracted from the license. Defined values are:
capacity
string
True
JSON string containing the capacity extracted from the license.
capacity2
string
True
JSON string containing the secondary capacity extracted from the license.
addons
array[addons]
False
JSON array of JSON objects containing the list of add-ons from the license. An add-on is a change in license occurring at a potential future date.
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
