Astra Automation
Retrieve an application asset for an app
GET /accounts/{account_id}/k8s/v1/apps/{app_id}/appAssets/{appAsset_id}
Returns the stored Application Asset API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
appAsset_id
string
path
True
ID of the appAsset collection to list
Status: 200, Returns the stored Application Asset API resource in the JSON response body.
type
string
True
  • "application/astra-appAsset"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
assetType
string
True
JSON string containing a value indicating what type of asset is being described as obtained from Kubernetes. Defined values are:
  • Minimum length: 1
  • Maximum length: 254
creationTimestamp
string
True
JSON string containing a timestamp indicating when the Kubernetes metadata was created. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
GVK
GVK
True
JSON object containing a Kubernetes group/version/kind.
resource
type_json
False
JSON object containing the entire content of the Kubernetes resource definition.
assetID
string
True
JSON string containing an identifier assigned by Kubernetes. Defined values are:
  • Conforms to the Astra Identifier Schema
labels
array[labels]
True
JSON array of JSON objects, each containing a Kubernetes labels associated with the asset. If no details are available, this array will be empty.
  • Minimum items: 0
assetName
string
True
JSON string containing a name assigned by Kubernetes. Defined values are:
  • Minimum length: 1
namespace
string
False
JSON string containing a namespace assigned by Kubernetes. Defined values are:
  • Minimum length: 1
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-appAsset",
  "version": "1.1",
  "id": "6415e851-b820-553b-9432-ebd057d1917d",
  "assetType": "Pod",
  "creationTimestamp": "2020-08-06T12:24:52.256624Z",
  "GVK": {
    "group": "apps",
    "kind": "Pod",
    "version": "v1"
  "assetID": "93ec0c61-d993-4aa1-bb08-f4dcdd5e97f6",
  "labels": [
      "name": "app",
      "value": "mediawiki"
      "name": "pod-template-hash",
      "value": "69c6fcf864"
  "assetName": "mediawiki-69c6fcf864-2wx6l",
  "namespace": "wiki",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
GVK
group
string
False
JSON string containing a group identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
kind
string
False
JSON string containing a kind identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
version
string
False
JSON string containing a version identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
type_json
labels
name
string
True
JSON string containing the label name Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Defined regex is: "^([\S.]{1,253}\/)?([a-z0-9A-Z_.-]){1,63}$"
value
string
True
JSON string containing the label value Defined values are:
  • Minimum length: 1
  • Defined regex is: "^([a-z0-9A-Z_.-]){1,63}$"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
