Astra Automation
Delete an execution hook for an app
Collaboratori
DELETE /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHooks/{executionHook_id}
Removes the specified Execution Hook API resource.
Side Effects
  • The deleted execution hook will no longer run as part of future actions.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
executionHook_id
string
path
True
ID of the executionHook collection to list
Status: 204, Indicates if the executionHook resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
JSON
invalidParams
name
string
True
reason
string
True
