Astra Automation
List the unread notifications for a user in a group
Collaboratori
GET /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/unreadNotifications
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
group_id
string
path
True
ID of the containing group resource
user_id
string
path
True
ID of the containing user resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: notificationID,sequenceCount
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
  • example: 2
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
  • example: count%20desc
skip
string
query
False
Indicates the number of resources to skip over when listing a collection.
URL examples: "skip=1"
OpenAPI examples: "1"
count
string
query
False
Indicates if the total number of resources should be returned in the metadata object.
URL examples: "count=true"
OpenAPI examples: "true"
  • example: true
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: unreadNotification_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-unreadNotifications",
  "version": "1.0",
  "items": [
      "4080cf5f-2261-4130-b8fb-8432e2e553e6",
      48923
      "1b4e89f1-2e70-4a08-a015-e7064b0fb703",
      47345
  "metadata": {
    "labels": [],
JSON
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
JSON
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-unreadNotification"
version
string
True
  • "1.0"
id
string
True
notificationID
string
True
JSON string containing a notification ID that is to be marked as read by the user creating the mark. Defined values are:
  • Conforms to the Astra Identifier Schema
sequenceCount
number
True
JSON number containing a sequence count associated with the notification specified by the notification ID.
severity
string
True
JSON string containing one of the following values that indicate the severity of the event. Defined values are:
  • "cleared" - Indicates that a previously reported event describing a condition is no longer active. An event with severity "cleared" will use the same summary and correlation ID to enable it to be matched up
  • "indeterminate" - Indicates that the severity cannot be determined
  • "informational" - Indicates a change in state that is both expected and normal (not defined in X.733)
  • "warning" - Indicates the detection of a potential or impending service-affecting fault before any significant effects have been felt
  • "critical" - Indicates that a service-affecting condition has occurred and immediate corrective action is required
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
