Astra Automation
Retrieve a role binding for a group associated with a user
GET /accounts/{account_id}/core/v1/users/{user_id}/groups/{group_id}/roleBindings/{roleBinding_id}
Returns the stored Role Binding API resource in the JSON response body. If the request is against /accounts/{account_id}/core/v1/users/{user_id}/roleBindings endpoint, only roleBinding resources where the user ID matches the user ID in the request URL will be permitted to be read. If the request is against /accounts/{account_id}/core/v1/groups/{group_id}/roleBindings, only roleBinding resources where the group ID matches the group ID in the request URL will be permitted to be read.
account_id
string
path
True
  • example: {{.Account}}
user_id
string
path
True
ID of the containing user resource
group_id
string
path
True
ID of the containing group resource
roleBinding_id
string
path
True
ID of the roleBinding collection to list
Status: 200
type
string
True
  • "application/astra-roleBinding"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
principalType
string
True
JSON string representing the type of the principal this binding is associated with. Defined values are:
  • "user"
  • "group" For principalType "user", a non-nil user ID is required. For principalType "group", a non-nil group ID is required.
userID
string
True
JSON string containing a user resource ID. Defined values are:
  • Conforms to the Astra Identifier Schema If not specified on create, a nil UUID will be used. Only userID or groupID can be specified on create.
groupID
string
True
JSON string containing a group resource ID. Defined values are:
accountID
string
True
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role
string
True
JSON string containing one of the four defined roles. Defined values are:
  • "viewer"
  • "member"
  • "admin"
  • "owner"
roleConstraints
array[string]
False
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
  • Conforms to Astra Role Constraints Schema If not specified on create, the value will be set to an array of size 1 containing string "*" representing "full scope". If not specified on update, the value will be preserved without modification. An empty array represents "no scope". Examples:
  • = Allow access to any resource: "roleConstraints": ["*"]
  • = deny access to all resources: "roleConstraints": []
  • = Allow access to a specific namespace resource only: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'" ]
  • = Allow access to a specific namespace and everything under it: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'.*" ]
  • = Allow access to all namespaces labelled "dev" in any cluster in any cloud, and everything under them: "roleConstraints": [ "namespaces:kubernetesLabels='dev.example.com/appname=dev'.*" ]
  • = Allow access to all namespace resources only: "roleConstraints": [ "namespaces:*" ]
  • = Allow access to all namespace resources and everything under them: "roleConstraints": [ "namespaces:." ]
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-roleBinding",
  "version": "1.1",
  "id": "a198f052-5cd7-59d3-9f27-9ea32a21fbca",
  "principalType": "user",
  "userID": "4c27d25a-9edb-4e85-9438-48dc8e917231",
  "groupID": "00000000-0000-0000-0000-000000000000",
  "accountID": "9fd87309-067f-48c9-a331-527796c14cf3",
  "role": "viewer",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
