Astra Automation
Retrieve a storage backend
Collaboratori
GET /accounts/{account_id}/topology/v1/storageBackends/{storageBackend_id}
Returns the stored Storage Backend API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
storageBackend_id
string
path
True
ID of the storageBackend collection to list
Status: 200, Returns the stored Storage Backend API resource in the JSON response body.
type
string
True
  • "application/astra-storageBackend"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
id
string
True
backendName
string
True
JSON string containing a user-specified name for the storage backend. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
backendType
string
True
JSON string containing a value indicating the type of the storage backend being represented. Defined values are:
  • "ontap" - The storage backend represents a NetApp ONTAP system
  • enum: ["ontap"]
  • example: ontap
backendVersion
string
True
JSON string containing a value indicating the version of the storage backend being represented. Defined values are:
  • Minimum length: 1
backendCredentialsName
string
True
JSON string containing a value indicating the name of one or more credential resources used for the storage backend. Allows for credential rotation where multiple credential objects have the same name. Defined values are:
  • Minimum length: 1
configVersion
string
False
JSON string containing a value indicating the active configuration to be used by the storage backend. Defined values are:
  • Minimum length: 1
state
string
True
JSON string containing a value indicating the operational state of the storage backend. Defined values are:
  • "discovered" - The storage backend has been discovered from a managed cluster
  • "running" - The storage backend is running normally
  • "unknown" - The state of the storage backend cannot be determined
  • "failed" - The storage backend is in an unavailable state
stateDesired
string
False
JSON string containing a value indicating the desired operational state of the storage backend. Defined values are:
  • "running" - The storage backend will be in a normal running state
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why a storage backend is unable to transition to "running", why it has transitioned to "failed" or "unknown", and/or why it is at risk of transitioning to "failed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
managedState
string
True
JSON string containing a value indicating the management state of the storage backend. Defined values are:
  • "pending" - The storage backend is scheduled to be discovered or added
  • "unmanaged" - The storage backend is in a "discovered" state, is not under management, and is eligible for management
  • "managed" - The storage backend is in a "running" or "unknown" state and is under management
managedStateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why the storage backend is ineligible to be managed. Defined values are:
  • Minimum length: 1
healthState
string
False
JSON string containing a value indicating the health state of the storage backend. Defined values are:
  • "indeterminate" - The health of the resource cannot be determined (for example, due to lack of connectivity)
  • "normal" - The resource has no known issues and can provide services in accordance with the interface specification
  • "warning" - The resource has known issues that do not prevent it providing services in accordance with the interface specification
  • "critical" - The resource has known issues that prevent it from providing services in accordance with the interface specification
healthStateUnready
array[string]
False
JSON array of JSON strings, each indicating a reason why a storage backend is not in a normal health state. Defined values are:
  • Minimum length: 1
protectionState
string
True
JSON string containing a value indicating the protection state of the storage backend. "unknown" for ONTAP. Defined values are:
  • "protected" - The storage backend has a protection policy defined and is in conformance with that policy
  • "partial" - The storage backend has a protection policy defined but is out of conformance with that policy
  • "none" - The storage backend is not protected
  • "unknown" - The storage backend protection policy conformance cannot be determined
  • enum: ["protected", "partial", "none", "unknown"]
  • example: protected
protectionStateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why a protection policy is out of conformance. Defined values are:
  • Minimum length: 1
capabilities
capabilities
True
JSON object containing this Storage Backend capabilities.
ontap
ontap
False
JSON object containing specific information related to ONTAP clusters.
  • additionalProperties: false
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-storageBackend",
  "version": "1.3",
  "id": "04ad4237-3c89-5ca5-8a40-282ab5eb6428",
  "backendName": "st1-45",
  "backendType": "ontap",
  "backendVersion": "9.8",
  "backendCredentialsName": "st1-45-cred",
  "state": "discovered",
  "stateUnready": [],
  "managedState": "unmanaged",
  "managedStateUnready": [],
  "protectionState": "unknown",
  "protectionStateUnready": [
    "Waiting for storage backend discovery"
  "capabilities": {
    "flexClone": "true",
    "snapMirror": "true",
    "s3": "true"
  "ontap": {
    "authenticationStyle": "basic",
    "backendManagementIP": "10.193.179.105",
    "managementIPs": [
      "10.193.188.110",
      "10.193.179.105",
      "10.193.179.106"
  "metadata": {
    "labels": [],
JSON
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
JSON
capabilities
flexClone
string
True
JSON string indicating if this Storage Backend supports FlexClone.
snapMirror
string
True
JSON string indicating if this Storage Backend supports SnapMirror.
s3
string
True
JSON string indicating if this Storage Backend supports s3.
ontap
authenticationStyle
string
True
JSON string indicating whether the ONTAP authentication is performed using a username/password combination or a certificate. Defined values are:
  • "basic" - Uses username/password
  • "certificate" - Uses certificate
  • enum: ["basic", "certificate"]
  • example: basic
backendManagementIP
string
False
JSON string containing the IP address used to connect to this ONTAP cluster.
managementIPs
array[string]
False
JSON array of JSON strings containing the list of all possible management IPs used to connect to this ONTAP cluster. This is used to correlate backends detected through Trident and storage backends in Astra.
  • uniqueItems: 1
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
