Appendice A: Values.yaml
Collaboratori kevin-hoke
Questa sezione fornisce un codice YAML di esempio per i valori utilizzati nella soluzione del database vettoriale NetApp .
root@node2:~# cat  values.yaml
## Enable or disable Milvus Cluster mode
cluster:
  enabled: true
image:
  all:
    repository: milvusdb/milvus
    tag: v2.3.4
    pullPolicy: IfNotPresent
    ## Optionally specify an array of imagePullSecrets.
    ## Secrets must be manually created in the namespace.
    ## ref: https://kubernetes.io/docs/tasks/configure-pod-container/pull-image-private-registry/
    # pullSecrets:
    #   - myRegistryKeySecretName
  tools:
    repository: milvusdb/milvus-config-tool
    tag: v0.1.2
# Global node selector
# If set, this will apply to all milvus components
# Individual components can be set to a different node selector
nodeSelector: {}
# Global tolerations
# Individual components can be set to a different tolerations
tolerations: []
# Global affinity
# Individual components can be set to a different affinity
affinity: {}
# Global labels and annotations
labels: {}
annotations: {}
# Extra configs for milvus.yaml
# If set, this config will merge into milvus.yaml
# Please follow the config structure in the milvus.yaml
# at https://github.com/milvus-io/milvus/blob/master/configs/milvus.yaml
# Note: this config will be the top priority which will override the config
# in the image and helm chart.
extraConfigFiles:
  user.yaml: |+
    #    For example enable rest http for milvus proxy
    #    proxy:
    #      http:
    #        enabled: true
    ##  Enable tlsMode and set the tls cert and key
    #  tls:
    #    serverPemPath: /etc/milvus/certs/tls.crt
    #    serverKeyPath: /etc/milvus/certs/tls.key
    #   common:
    #     security:
    #       tlsMode: 1
## Expose the Milvus service to be accessed from outside the cluster (LoadBalancer service).
## or access it from within the cluster (ClusterIP service). Set the service type and the port to serve it.
## ref: http://kubernetes.io/docs/user-guide/services/
service:
  type: ClusterIP
  port: 19530
  portName: milvus
  nodePort: ""
  annotations: {}
  labels: {}
  ## List of IP addresses at which the Milvus service is available
  ## Ref: https://kubernetes.io/docs/user-guide/services/#external-ips
  externalIPs: []
  #   - externalIp1
  # LoadBalancerSourcesRange is a list of allowed CIDR values, which are combined with ServicePort to
  # set allowed inbound rules on the security group assigned to the master load balancer
  loadBalancerSourceRanges:
  - 0.0.0.0/0
  # Optionally assign a known public LB IP
  # loadBalancerIP: 1.2.3.4
ingress:
  enabled: false
  annotations:
    # Annotation example: set nginx ingress type
    # kubernetes.io/ingress.class: nginx
    nginx.ingress.kubernetes.io/backend-protocol: GRPC
    nginx.ingress.kubernetes.io/listen-ports-ssl: '[19530]'
    nginx.ingress.kubernetes.io/proxy-body-size: 4m
    nginx.ingress.kubernetes.io/ssl-redirect: "true"
  labels: {}
  rules:
    - host: "milvus-example.local"
      path: "/"
      pathType: "Prefix"
    # - host: "milvus-example2.local"
    #   path: "/otherpath"
    #   pathType: "Prefix"
  tls: []
  #  - secretName: chart-example-tls
  #    hosts:
  #      - milvus-example.local
serviceAccount:
  create: false
  name:
  annotations:
  labels:
metrics:
  enabled: true
  serviceMonitor:
    # Set this to `true` to create ServiceMonitor for Prometheus operator
    enabled: false
    interval: "30s"
    scrapeTimeout: "10s"
    # Additional labels that can be used so ServiceMonitor will be discovered by Prometheus
    additionalLabels: {}
livenessProbe:
  enabled: true
  initialDelaySeconds: 90
  periodSeconds: 30
  timeoutSeconds: 5
  successThreshold: 1
  failureThreshold: 5
readinessProbe:
  enabled: true
  periodSeconds: 10
  timeoutSeconds: 5
  successThreshold: 1
  failureThreshold: 5
log:
  level: "info"
  file:
    maxSize: 300    # MB
    maxAge: 10    # day
    maxBackups: 20
  format: "text"    # text/json
  persistence:
    mountPath: "/milvus/logs"
    ## If true, create/use a Persistent Volume Claim
    ## If false, use emptyDir
    enabled: false
    annotations:
      helm.sh/resource-policy: keep
    persistentVolumeClaim:
      existingClaim: ""
      ## Milvus Logs Persistent Volume Storage Class
      ## If defined, storageClassName: <storageClass>
      ## If set to "-", storageClassName: "", which disables dynamic provisioning
      ## If undefined (the default) or set to null, no storageClassName spec is
      ##   set, choosing the default provisioner.
      ## ReadWriteMany access mode required for milvus cluster.
      storageClass: default
      accessModes: ReadWriteMany
      subPath: ""
## Heaptrack traces all memory allocations and annotates these events with stack traces.
## See more: https://github.com/KDE/heaptrack
## Enable heaptrack in production is not recommended.
heaptrack:
  image:
    repository: milvusdb/heaptrack
    tag: v0.1.0
standalone:
  replicas: 1  # Run standalone mode with replication disabled
  resources: {}
  # Set local storage size in resources
  # limits:
  #    ephemeral-storage: 100Gi
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  disk:
    enabled: true
    size:
      enabled: false  # Enable local storage size limit
  profiling:
    enabled: false  # Enable live profiling
  ## Default message queue for milvus standalone
  ## Supported value: rocksmq, natsmq, pulsar and kafka
  messageQueue: rocksmq
  persistence:
    mountPath: "/var/lib/milvus"
    ## If true, alertmanager will create/use a Persistent Volume Claim
    enabled: true
    annotations:
      existingClaim: ""
      ## Milvus Persistent Volume Storage Class
      storageClass:
      accessModes: ReadWriteOnce
      subPath: ""
proxy:
  enabled: true
  # You can set the number of replicas to -1 to remove the replicas field in case you want to use HPA
  replicas: 1
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  http:
    enabled: true  # whether to enable http rest server
    debugMode:
      enabled: false
  # Mount a TLS secret into proxy pod
  tls:
    enabled: false
## when enabling proxy.tls, all items below should be uncommented and the key and crt values should be populated.
#    enabled: true
#    secretName: milvus-tls
## expecting base64 encoded values here: i.e. $(cat tls.crt | base64 -w 0) and $(cat tls.key | base64 -w 0)
#    key: LS0tLS1CRUdJTiBQU--REDUCT
#    crt: LS0tLS1CRUdJTiBDR--REDUCT
#  volumes:
#  - secret:
#    name: milvus-tls
#  volumeMounts:
#  - mountPath: /etc/milvus/certs/
#    name: milvus-tls
rootCoordinator:
  enabled: true
  # You can set the number of replicas greater than 1, only if enable active standby
  replicas: 1  # Run Root Coordinator mode with replication disabled
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  activeStandby:
    enabled: false  # Enable active-standby when you set multiple replicas for root coordinator
  service:
    port: 53100
    annotations: {}
    labels: {}
    clusterIP: ""
queryCoordinator:
  enabled: true
  replicas: 1  # Run Query Coordinator mode with replication disabled
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  activeStandby:
    enabled: false  # Enable active-standby when you set multiple replicas for query coordinator
  service:
    port: 19531
    annotations: {}
    labels: {}
    clusterIP: ""
queryNode:
  enabled: true
  replicas: 1
  resources: {}
  # limits:
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  disk:
    enabled: true  # Enable querynode load disk index, and search on disk index
    size:
  profiling:
indexCoordinator:
  enabled: true
  replicas: 1   # Run Index Coordinator mode with replication disabled
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  activeStandby:
    enabled: false  # Enable active-standby when you set multiple replicas for index coordinator
  service:
    port: 31000
    annotations: {}
    labels: {}
    clusterIP: ""
indexNode:
  enabled: true
  replicas: 1
  resources: {}
  # limits:
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  disk:
    enabled: true  # Enable index node build disk vector index
    size:
dataCoordinator:
  enabled: true
  replicas: 1           # Run Data Coordinator mode with replication disabled
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  activeStandby:
    enabled: false  # Enable active-standby when you set multiple replicas for data coordinator
  service:
    port: 13333
    annotations: {}
    labels: {}
    clusterIP: ""
dataNode:
  enabled: true
  replicas: 1
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
## mixCoordinator contains all coord
## If you want to use mixcoord, enable this and disable all of other coords
mixCoordinator:
  enabled: false
  replicas: 1           # Run Mixture Coordinator mode with replication disabled
  resources: {}
  nodeSelector: {}
  affinity: {}
  tolerations: []
  extraEnv: []
  heaptrack:
    enabled: false
  profiling:
  activeStandby:
    enabled: false  # Enable active-standby when you set multiple replicas for Mixture coordinator
  service:
    annotations: {}
    labels: {}
    clusterIP: ""
attu:
  enabled: false
  image:
    repository: zilliz/attu
    tag: v2.2.8
  service:
    annotations: {}
    labels: {}
    type: ClusterIP
    port: 3000
    # loadBalancerIP: ""
  resources: {}
  podLabels: {}
  ingress:
    enabled: false
    annotations: {}
    labels: {}
    hosts:
      - milvus-attu.local
    tls: []
    #  - secretName: chart-attu-tls
    #    hosts:
    #      - milvus-attu.local
## Configuration values for the minio dependency
## ref: https://github.com/minio/charts/blob/master/README.md
minio:
  enabled: false
  mode: distributed
  image:
    tag: "RELEASE.2023-03-20T20-16-18Z"
  accessKey: minioadmin
  secretKey: minioadmin
  existingSecret: ""
  bucketName: "milvus-bucket"
  rootPath: file
  useIAM: false
  iamEndpoint: ""
  region: ""
  useVirtualHost: false
  podDisruptionBudget:
    enabled: false
  resources:
    requests:
      memory: 2Gi
  gcsgateway:
    enabled: false
    replicas: 1
    gcsKeyJson: "/etc/credentials/gcs_key.json"
    projectId: ""
  service:
    type: ClusterIP
    port: 9000
  persistence:
    enabled: true
    existingClaim: ""
    storageClass:
    accessMode: ReadWriteOnce
  livenessProbe:
    enabled: true
    initialDelaySeconds: 5
    periodSeconds: 5
    timeoutSeconds: 5
    successThreshold: 1
    failureThreshold: 5
  readinessProbe:
    enabled: true
    periodSeconds: 5
    timeoutSeconds: 1
    successThreshold: 1
    failureThreshold: 5
  startupProbe:
    enabled: true
    initialDelaySeconds: 0
    periodSeconds: 10
    timeoutSeconds: 5
    successThreshold: 1
    failureThreshold: 60
## Configuration values for the etcd dependency
## ref: https://artifacthub.io/packages/helm/bitnami/etcd
etcd:
  enabled: true
  replicaCount: 3
  pdb:
    create: false
  image:
    repository: "milvusdb/etcd"
    tag: "3.5.5-r2"
  service:
    type: ClusterIP
    port: 2379
    peerPort: 2380
  auth:
    rbac:
      enabled: false
  persistence:
    enabled: true
  ## Change default timeout periods to mitigate zoobie probe process
  livenessProbe:
    enabled: true
    timeoutSeconds: 10
  readinessProbe:
    enabled: true
    periodSeconds: 20
    timeoutSeconds: 10
  ## Enable auto compaction
  ## compaction by every 1000 revision
  autoCompactionMode: revision
  autoCompactionRetention: "1000"
  ## Increase default quota to 4G
  extraEnvVars:
  - name: ETCD_QUOTA_BACKEND_BYTES
    value: "4294967296"
  - name: ETCD_HEARTBEAT_INTERVAL
    value: "500"
  - name: ETCD_ELECTION_TIMEOUT
    value: "2500"
## Configuration values for the pulsar dependency
## ref: https://github.com/apache/pulsar-helm-chart
pulsar:
  enabled: true
  fullnameOverride: ""
  persistence: true
  maxMessageSize: "5242880"  # 5 * 1024 * 1024 Bytes, Maximum size of each message in pulsar.
  rbac:
    enabled: false
    psp: false
    limit_to_namespace: true
  affinity:
    anti_affinity: false
## enableAntiAffinity: no
  components:
    zookeeper: true
    bookkeeper: true
    # bookkeeper - autorecovery
    autorecovery: true
    broker: true
    functions: false
    proxy: true
    toolset: false
    pulsar_manager: false
  monitoring:
    prometheus: false
    grafana: false
    node_exporter: false
    alert_manager: false
  images:
    broker:
      repository: apachepulsar/pulsar
      tag: 2.8.2
    autorecovery:
      tag: 2.8.2
    zookeeper:
      tag: 2.8.2
    bookie:
      tag: 2.8.2
    proxy:
      tag: 2.8.2
    pulsar_manager:
      repository: apachepulsar/pulsar-manager
      tag: v0.1.0
  zookeeper:
    volumes:
      persistence: true
      data:
        size: 20Gi   #SSD Required
        storageClassName: default
    resources:
      requests:
        memory: 1024Mi
        cpu: 0.3
    configData:
      PULSAR_MEM: >
        -Xms1024m
        -Xmx1024m
      PULSAR_GC: >
         -Dcom.sun.management.jmxremote
         -Djute.maxbuffer=10485760
         -XX:+ParallelRefProcEnabled
         -XX:+UnlockExperimentalVMOptions
         -XX:+DoEscapeAnalysis
         -XX:+DisableExplicitGC
         -XX:+PerfDisableSharedMem
         -Dzookeeper.forceSync=no
    pdb:
      usePolicy: false
  bookkeeper:
    replicaCount: 3
    volumes:
      persistence: true
      journal:
      ledgers:
    resources:
      requests:
        memory: 2048Mi
        cpu: 1
    configData:
      PULSAR_MEM: >
        -Xms4096m
        -Xmx4096m
        -XX:MaxDirectMemorySize=8192m
      PULSAR_GC: >
        -Dio.netty.leakDetectionLevel=disabled
        -Dio.netty.recycler.linkCapacity=1024
        -XX:+UseG1GC -XX:MaxGCPauseMillis=10
        -XX:ParallelGCThreads=32
        -XX:ConcGCThreads=32
        -XX:G1NewSizePercent=50
        -XX:-ResizePLAB
        -XX:+ExitOnOutOfMemoryError
        -XX:+PrintGCDetails
      nettyMaxFrameSizeBytes: "104867840"
    pdb:
      usePolicy: false
  broker:
    component: broker
    podMonitor:
      enabled: false
    replicaCount: 1
    resources:
      requests:
        memory: 4096Mi
        cpu: 1.5
    configData:
      PULSAR_MEM: >
        -Xms4096m
        -Xmx4096m
      PULSAR_GC: >
        -XX:-ResizePLAB
      maxMessageSize: "104857600"
      defaultRetentionTimeInMinutes: "10080"
      defaultRetentionSizeInMB: "-1"
      backlogQuotaDefaultLimitGB: "8"
      ttlDurationDefaultInSeconds: "259200"
      subscriptionExpirationTimeMinutes: "3"
      backlogQuotaDefaultRetentionPolicy: producer_exception
    pdb:
      usePolicy: false
  autorecovery:
    resources:
      requests:
        memory: 512Mi
        cpu: 1
  proxy:
    replicaCount: 1
    podMonitor:
      enabled: false
    resources:
      requests:
        memory: 2048Mi
        cpu: 1
    service:
      type: ClusterIP
    ports:
      pulsar: 6650
    configData:
      PULSAR_MEM: >
        -Xms2048m -Xmx2048m
      PULSAR_GC: >
        -XX:MaxDirectMemorySize=2048m
      httpNumThreads: "100"
    pdb:
      usePolicy: false
  pulsar_manager:
    service:
      type: ClusterIP
  pulsar_metadata:
    component: pulsar-init
    image:
      # the image used for running `pulsar-cluster-initialize` job
      tag: 2.8.2
## Configuration values for the kafka dependency
## ref: https://artifacthub.io/packages/helm/bitnami/kafka
kafka:
  enabled: false
  replicaCount: 3
  image:
    repository: bitnami/kafka
    tag: 3.1.0-debian-10-r52
  ## Increase graceful termination for kafka graceful shutdown
  terminationGracePeriodSeconds: "90"
  pdb:
    create: false
  ## Enable startup probe to prevent pod restart during recovering
  startupProbe:
    enabled: true
  ## Kafka Java Heap size
  heapOpts: "-Xmx4096m -Xms4096m"
  maxMessageBytes: _10485760
  defaultReplicationFactor: 3
  offsetsTopicReplicationFactor: 3
  ## Only enable time based log retention
  logRetentionHours: 168
  logRetentionBytes: _-1
  extraEnvVars:
  - name: KAFKA_CFG_MAX_PARTITION_FETCH_BYTES
    value: "5242880"
  - name: KAFKA_CFG_MAX_REQUEST_SIZE
    value: "5242880"
  - name: KAFKA_CFG_REPLICA_FETCH_MAX_BYTES
    value: "10485760"
  - name: KAFKA_CFG_FETCH_MESSAGE_MAX_BYTES
    value: "5242880"
  - name: KAFKA_CFG_LOG_ROLL_HOURS
    value: "24"
  persistence:
    enabled: true
    storageClass:
  metrics:
    ## Prometheus Kafka exporter: exposes complimentary metrics to JMX exporter
    kafka:
      enabled: false
      image:
        repository: bitnami/kafka-exporter
        tag: 1.4.2-debian-10-r182
    ## Prometheus JMX exporter: exposes the majority of Kafkas metrics
    jmx:
      enabled: false
      image:
        repository: bitnami/jmx-exporter
        tag: 0.16.1-debian-10-r245
    ## To enable serviceMonitor, you must enable either kafka exporter or jmx exporter.
    ## And you can enable them both
    serviceMonitor:
      enabled: false
  service:
    type: ClusterIP
    ports:
      client: 9092
  zookeeper:
    enabled: true
    replicaCount: 3
# External S3
# - these configs are only used when `externalS3.enabled` is true
externalS3:
  enabled: true
  host: "192.168.150.167"
  port: "80"
  accessKey: "24G4C1316APP2BIPDE5S"
  secretKey: "Zd28p43rgZaU44PX_ftT279z9nt4jBSro97j87Bx"
  useSSL: false
  bucketName: "milvusdbvol1"
  rootPath: ""
  useIAM: false
  cloudProvider: "aws"
  iamEndpoint: ""
  region: ""
# GCS Gateway
# - these configs are only used when `minio.gcsgateway.enabled` is true
externalGcs:
  bucketName: ""
# External etcd
# - these configs are only used when `externalEtcd.enabled` is true
externalEtcd:
  enabled: false
  ## the endpoints of the external etcd
  endpoints:
    - localhost:2379
# External pulsar
# - these configs are only used when `externalPulsar.enabled` is true
externalPulsar:
  enabled: false
  host: localhost
  port: 6650
  tenant: public
  namespace: default
  authPlugin: ""
  authParams: ""
# External kafka
# - these configs are only used when `externalKafka.enabled` is true
externalKafka:
  enabled: false
  brokerList: localhost:9092
  securityProtocol: SASL_SSL
  sasl:
    mechanisms: PLAIN
    username: ""
    password: ""
root@node2:~#
