Configurare le relazioni di replica su FSX per i file system ONTAP
Per ulteriori informazioni sulle opzioni di configurazione di SnapMirror, consultare la documentazione di ONTAP all'indirizzo "Workflow di replica di SnapMirror (netapp.com)".
FSX di origine per il file system ONTAP:
FsxId00fa9e3c784b6abbb -
SVM di origine:
sapcc-hana-svm -
FSX di destinazione per il file system ONTAP:
FsxId05f7f00af49dc7a3e -
SVM di destinazione:
sapcc-backup-target-zone5
Peer FSX per file system ONTAP
FsxId00fa9e3c784b6abbb::> network interface show -role intercluster
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
inter_1 up/up 10.1.1.57/24 FsxId00fa9e3c784b6abbb-01
e0e true
inter_2 up/up 10.1.2.7/24 FsxId00fa9e3c784b6abbb-02
e0e true
2 entries were displayed.
FsxId05f7f00af49dc7a3e::> network interface show -role intercluster
inter_1 up/up 10.1.2.144/24 FsxId05f7f00af49dc7a3e-01
e0e true
inter_2 up/up 10.1.2.69/24 FsxId05f7f00af49dc7a3e-02
e0e true
FsxId05f7f00af49dc7a3e::> cluster peer create -address-family ipv4 -peer-addrs 10.1.1.57, 10.1.2.7 Notice: Use a generated passphrase or choose a passphrase of 8 or more characters. To ensure the authenticity of the peering relationship, use a phrase or sequence of characters that would be hard to guess. Enter the passphrase: Confirm the passphrase: Notice: Now use the same passphrase in the "cluster peer create" command in the other cluster.
peer-addrs Sono gli IP del cluster di destinazione.
FsxId00fa9e3c784b6abbb::> cluster peer create -address-family ipv4 -peer-addrs 10.1.2.144, 10.1.2.69
FsxId00fa9e3c784b6abbb::> cluster peer show
Peer Cluster Name Cluster Serial Number Availability Authentication
FsxId05f7f00af49dc7a3e 1-80-000011 Available ok
SVM peer
FsxId05f7f00af49dc7a3e::> vserver peer create -vserver sapcc-backup-target-zone5 -peer-vserver sapcc-hana-svm -peer-cluster FsxId00fa9e3c784b6abbb -applications snapmirror Info: [Job 41] 'vserver peer create' job queued
FsxId00fa9e3c784b6abbb::> vserver peer accept -vserver sapcc-hana-svm -peer-vserver sapcc-backup-target-zone5 Info: [Job 960] 'vserver peer accept' job queued
FsxId05f7f00af49dc7a3e::> vserver peer show
Peer Peer Peering Remote
Vserver Vserver State Peer Cluster Applications Vserver
peer-source-cluster
peered FsxId00fa9e3c784b6abbb
snapmirror sapcc-hana-svm
Creare un volume di destinazione
È necessario creare il volume di destinazione con il tipo DP per contrassegnarlo come destinazione di replica.
FsxId05f7f00af49dc7a3e::> volume create -vserver sapcc-backup-target-zone5 -volume PFX_data_mnt00001 -aggregate aggr1 -size 100GB -state online -policy default -type DP -autosize-mode grow_shrink -snapshot-policy none -foreground true -tiering-policy all -anti-ransomware-state disabled [Job 42] Job succeeded: Successful
Creare un criterio SnapMirror
Il criterio SnapMirror e la regola aggiunta definiscono la conservazione e l'etichetta SnapMirror per identificare le istantanee da replicare. Quando si crea il criterio SnapCenter in un secondo momento, è necessario utilizzare la stessa etichetta.
FsxId05f7f00af49dc7a3e::> snapmirror policy create -policy snapcenter-policy -tries 8 -transfer-priority normal -ignore-atime false -restart always -type vault -vserver sapcc-backup-target-zone5
FsxId05f7f00af49dc7a3e::> snapmirror policy add-rule -vserver sapcc-backup-target-zone5 -policy snapcenter-policy -snapmirror-label snapcenter -keep 14
FsxId00fa9e3c784b6abbb::> snapmirror policy showVserver Policy Policy Number Transfer
Name Name Type Of Rules Tries Priority Comment
snapcenter-policy vault 1 8 normal -
SnapMirror Label: snapcenter Keep: 14
Total Keep: 14
Creare una relazione SnapMirror
Ora viene definita la relazione tra il volume di origine e quello di destinazione, oltre al tipo XDP e alla policy creata in precedenza.
FsxId05f7f00af49dc7a3e::> snapmirror create -source-path sapcc-hana-svm:PFX_data_mnt00001 -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -vserver sapcc-backup-target-zone5 -throttle unlimited -identity-preserve false -type XDP -policy snapcenter-policy Operation succeeded: snapmirror create for the relationship with destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
Inizializzare SnapMirror
Con questo comando, viene avviata la replica iniziale. Si tratta di un trasferimento completo di tutti i dati dal volume di origine al volume di destinazione.
FsxId05f7f00af49dc7a3e::> snapmirror initialize -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -source-path sapcc-hana-svm:PFX_data_mnt00001 Operation is queued: snapmirror initialize of destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
È possibile controllare lo stato della replica con snapmirror show comando.
FsxId05f7f00af49dc7a3e::> snapmirror show
Progress
Source Destination Mirror Relationship Total Last
Path Type Path State Status Progress Healthy Updated
XDP sapcc-backup-target-zone5:PFX_data_mnt00001
Uninitialized
Transferring 1009MB true 02/24 12:34:28
Progress
Snapmirrored
Idle - true -
